Saltar al contenido principal
Canon PowerShot SD1000 Back Panel Replacement
Phillip Phung
Phillip Phung y 16 otros contribuidores
Última actualización: June 25, 2024
5 minuto
Fácil
Necesita mejores imágenes
Introducción
Ir al paso 1
The back panel of the Canon PowerShot SD1000 protects the internal components and adds to the overall aesthetic. Over time the back panel may receive wear and tear, cracks, and other damages that need replacement. Properly replacing the back panel increases the lifespan of your camera.
Before using this guide, please look over the back panel for corrosion or metal shards. This can cause a safety hazard when opening the back panel. If found, please wear protective gloves to avoid direct skin contact.
This manual will show you step-by-step instructions for replacing the back panel, safety precautions, highlight tools needed, and tips to achieve a professional result.
Qué necesitas
Herramientas
  1. Canon PowerShot SD1000 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 Canon PowerShot SD1000 Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Back Panel Replacement: paso 2, imagen 1 de 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Back Panel Replacement: paso 3, imagen 1 de 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Back Panel Replacement: paso 4, imagen 1 de 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Back Panel Replacement: paso 5, imagen 1 de 1
    • Remove the small cover panel and the attached wrist strap mount.
Conclusión
Una persona más ha completado esta guía.
Phillip Phung
Miembro Desde 01/19/12
651 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 8-18, Maness Winter 2012 Miembro de Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
Miembros de 4
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,002
