Saltar al contenido principal
Canon PowerShot S80 LCD Screen Replacement
BrettH
BrettH y 7 otros contribuidores
Última actualización: January 5, 2024
30 minuto
Moderado
Introducción
Ir al paso 1
The LCD screen of the Canon PowerShot S80 is necessary for the normal operation of the camera. The screen is also vulnerable to cracks, chips and water damage. This guide will show you how to replace your LCD screen.
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Canon PowerShot S80 LCD Screen Replacement, Outer Casing: paso 1, imagen 1 de 2 Canon PowerShot S80 LCD Screen Replacement, Outer Casing: paso 1, imagen 2 de 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 LCD Screen Replacement: paso 2, imagen 1 de 2 Canon PowerShot S80 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 LCD Screen Replacement: paso 3, imagen 1 de 3 Canon PowerShot S80 LCD Screen Replacement: paso 3, imagen 2 de 3 Canon PowerShot S80 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 LCD Screen Replacement: paso 4, imagen 1 de 3 Canon PowerShot S80 LCD Screen Replacement: paso 4, imagen 2 de 3 Canon PowerShot S80 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 LCD Screen Replacement: paso 6, imagen 1 de 2 Canon PowerShot S80 LCD Screen Replacement: paso 6, imagen 2 de 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
Conclusión
3 personas más completaron esta guía.
BrettH
Miembro Desde 10/28/09
219 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 19-5, Maness SU 2012 Miembro de Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Miembro
5 Guías creadas
2 comentarios
I presume the narrow ribbon cable supplies power to the backlight behind the screen? I replaced the combined screen and backlight assembly. I now have an image but it is extremely dark, barely visible. Perhaps the backlight didn't come on?
The contacts on both the wide ribbon and the narrow ribbon were corroded, probably the source of the problem.
Any suggestions?
Clive Williams - Contestar
I found very easy to follow the instructions provided. I just commenta that the last step should be completed by the separation between the screen and the support plate, which is not shown. However if one reaches that point (having the replacement part at hands) it has easy to find the next step of the “surgery”.
Goodinstruction. Thanks to this I brought to new life my Canon Powrr shot S80
attilio.brighenti - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 7,356
