Saltar al contenido principal
Canon PowerShot S80 Flash Replacement
BrettH
BrettH y 7 otros contribuidores
Última actualización: May 7, 2024
30 - 45 minutos
Moderado
Introducción
Ir al paso 1
This guide serves to replace a faulty flash mechanism.
Qué necesitas
Herramientas
Ver más…
  1. Canon PowerShot S80 Flash Replacement, Outer Casing: paso 1, imagen 1 de 2 Canon PowerShot S80 Flash Replacement, Outer Casing: paso 1, imagen 2 de 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Flash Replacement: paso 2, imagen 1 de 2 Canon PowerShot S80 Flash Replacement: paso 2, imagen 2 de 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Flash Replacement: paso 3, imagen 1 de 3 Canon PowerShot S80 Flash Replacement: paso 3, imagen 2 de 3 Canon PowerShot S80 Flash Replacement: paso 3, imagen 3 de 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Flash Replacement: paso 4, imagen 1 de 3 Canon PowerShot S80 Flash Replacement: paso 4, imagen 2 de 3 Canon PowerShot S80 Flash Replacement: paso 4, imagen 3 de 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: paso 5, imagen 1 de 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Flash Replacement: paso 6, imagen 1 de 2 Canon PowerShot S80 Flash Replacement: paso 6, imagen 2 de 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Flash Replacement, Flash: paso 7, imagen 1 de 1
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Canon PowerShot S80 Flash Replacement: paso 8, imagen 1 de 2 Canon PowerShot S80 Flash Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. Canon PowerShot S80 Flash Replacement: paso 9, imagen 1 de 1
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. Canon PowerShot S80 Flash Replacement: paso 10, imagen 1 de 1
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Canon PowerShot S80 Flash Replacement: paso 11, imagen 1 de 1
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Canon PowerShot S80 Flash Replacement: paso 12, imagen 1 de 1
    • Lift the flash bulb unit upwards from the camera.
  13. Canon PowerShot S80 Flash Replacement: paso 13, imagen 1 de 2 Canon PowerShot S80 Flash Replacement: paso 13, imagen 2 de 2
    • Lift the entire three-part flash assembly from the camera.
Conclusión
BrettH
Miembro Desde 10/28/09
219 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 19-5, Maness SU 2012 Miembro de Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Miembro
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 3,697
