Saltar al contenido principal
Canon PowerShot S230 Battery Replacement
Tanya Malalang
Tanya Malalang y 13 otros contribuidores
Última actualización: February 18, 2025
45 minuto
Moderado
Estudiante en Progreso
Introducción
Ir al paso 1
If your Canon Powershot S230 camera is not turning on or is not retaining its charge, the issue may be that the battery is no longer functional. The battery supplies power to the device and is therefore vital to the camera’s operation.
Before you move forward with the guide, make sure you are informed of what to do with a swollen battery and the safety concerns related to removing batteries.
This guide will walk you through how to find and replace the battery in the Canon PowerShot S230 camera with the use of visual representations to help guide you through the process.
  1. Canon PowerShot S230 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
  2. Canon PowerShot S230 Battery Replacement: paso 2, imagen 1 de 1
    • Hold the end of the battery cover that extends beyond the camera and lift it up.
  3. Canon PowerShot S230 Battery Replacement: paso 3, imagen 1 de 1
    • Locate the orange tab next to the battery. Next roll the tab back in order for the battery to come out.
  4. Canon PowerShot S230 Battery Replacement: paso 4, imagen 1 de 1
    • Pull the battery out.
Conclusión
Ensure all connections are secure, and the camera functions correctly before closing the final casing screws.
Tanya Malalang
Miembro Desde 01/12/11
325 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-1, Forte Winter 2011 Miembro de Cal Poly, Team 13-1, Forte Winter 2011
CPSU-FORTE-W11S13G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 1,820
