Saltar al contenido principal
Canon PowerShot S100 Top Panel Replacement
Ricky
Ricky y 4 otros contribuidores
Última actualización: May 7, 2024
15 minuto
Fácil
Introducción
Ir al paso 1
The top panel of the camera grants access to the shutter button and the rotating dial. Removing the top panel is also necessary to access and remove other internal parts.
Qué necesitas
Herramientas
Ver más…
  1. Canon PowerShot S100 Top Panel Replacement, Outer Case: paso 1, imagen 1 de 3 Canon PowerShot S100 Top Panel Replacement, Outer Case: paso 1, imagen 2 de 3 Canon PowerShot S100 Top Panel Replacement, Outer Case: paso 1, imagen 3 de 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Top Panel Replacement: paso 2, imagen 1 de 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Top Panel Replacement: paso 3, imagen 1 de 3 Canon PowerShot S100 Top Panel Replacement: paso 3, imagen 2 de 3 Canon PowerShot S100 Top Panel Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 Top Panel Replacement, Top Panel: paso 4, imagen 1 de 1
    • Turn the camera over on its side so that the terminals are facing you.
    • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
  5. Canon PowerShot S100 Top Panel Replacement: paso 5, imagen 1 de 2 Canon PowerShot S100 Top Panel Replacement: paso 5, imagen 2 de 2
    • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
  6. Canon PowerShot S100 Top Panel Replacement: paso 6, imagen 1 de 2 Canon PowerShot S100 Top Panel Replacement: paso 6, imagen 2 de 2
    • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
    • Gently lift the top panel off the camera.
    • Tweezers may also be used to remove the ribbon cable.
Conclusión
3 personas más completaron esta guía.
Ricky
Miembro Desde 02/23/15
968 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-4, Leahy Winter 2015 Miembro de USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 Miembros
5 Guías creadas
Un comentario
Ricky hi please I need some help! I repaired the screen but now the flash will not turn on! When I press the button the flash on the screen still says it is not on, and the flash itself will not pop out! What do I do!
Emily - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 2,292
