Saltar al contenido principal
Canon PowerShot G7X Lens Replacement
Kyle Pellham
Kyle Pellham y 3 otros contribuidores
Última actualización: June 15, 2018
15 - 20 minutos
Moderado
Introducción
Ir al paso 1
The lens is essential in any camera. Any flaw in a lens will ruin a cameras ability to operate. This guide will detail the steps required to replace the camera lens for a Canon Powershot G7X.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Canon PowerShot G7X Lens Replacement, Dial: paso 1, imagen 1 de 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Lens Replacement: paso 2, imagen 1 de 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Lens Replacement: paso 3, imagen 1 de 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Lens Replacement: paso 4, imagen 1 de 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Lens Replacement: paso 5, imagen 1 de 1
    • Remove the back plate.
  6. Canon PowerShot G7X Lens Replacement: paso 6, imagen 1 de 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Lens Replacement: paso 7, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 7, imagen 2 de 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Lens Replacement, Flash: paso 8, imagen 1 de 2 Canon PowerShot G7X Lens Replacement, Flash: paso 8, imagen 2 de 2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Lens Replacement: paso 9, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 9, imagen 2 de 2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Lens Replacement: paso 10, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 10, imagen 2 de 2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Lens Replacement: paso 11, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 11, imagen 2 de 2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Lens Replacement: paso 12, imagen 1 de 1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Lens Replacement: paso 13, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 13, imagen 2 de 2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Lens Replacement: paso 14, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 14, imagen 2 de 2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Lens Replacement: paso 15, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 15, imagen 2 de 2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
  16. Canon PowerShot G7X Lens Replacement, Lens: paso 16, imagen 1 de 1
    • Remove the 5 mm Phillips #000 screw from the copper plate.
  17. Canon PowerShot G7X Lens Replacement: paso 17, imagen 1 de 1
    • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
  18. Canon PowerShot G7X Lens Replacement: paso 18, imagen 1 de 1
    • Remove the copper plate to reveal connections to the lens.
  19. Canon PowerShot G7X Lens Replacement: paso 19, imagen 1 de 1
    • Using the black nylon spudger, lift gently on the pin connector until it comes off.
  20. Canon PowerShot G7X Lens Replacement: paso 20, imagen 1 de 2 Canon PowerShot G7X Lens Replacement: paso 20, imagen 2 de 2
    • Using the spudger, gently lift on the ribbon cable until it comes out.
    • Separate the lens from the motherboard.
Conclusión
Una persona más ha completado esta guía.
3 comentarios
Not that great of step by step. Lots of missed steps and lots different screw length and thread. Over all it's just an ok guide.
Nick Thomas - Contestar
how do you tell if the lens is CCD or not
kingwayne77none - Contestar
Poor instructions indeed. At step 11 silver plate still stuck. More screws than indicated.
Hugo Lyppens - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 47
Todo El Tiempo: 7,389
