Saltar al contenido principal
Canon PowerShot G7X Flash Replacement
Qué necesitas
  1. Canon PowerShot G7X Flash Replacement, Dial: paso 1, imagen 1 de 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Flash Replacement: paso 2, imagen 1 de 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Flash Replacement: paso 3, imagen 1 de 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Flash Replacement: paso 4, imagen 1 de 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Flash Replacement: paso 5, imagen 1 de 1
    • Remove the back plate.
  6. Canon PowerShot G7X Flash Replacement: paso 6, imagen 1 de 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Flash Replacement: paso 7, imagen 1 de 2 Canon PowerShot G7X Flash Replacement: paso 7, imagen 2 de 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Flash Replacement, Flash: paso 8, imagen 1 de 2 Canon PowerShot G7X Flash Replacement, Flash: paso 8, imagen 2 de 2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Flash Replacement: paso 9, imagen 1 de 2 Canon PowerShot G7X Flash Replacement: paso 9, imagen 2 de 2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Flash Replacement: paso 10, imagen 1 de 2 Canon PowerShot G7X Flash Replacement: paso 10, imagen 2 de 2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Flash Replacement: paso 11, imagen 1 de 2 Canon PowerShot G7X Flash Replacement: paso 11, imagen 2 de 2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Flash Replacement: paso 12, imagen 1 de 1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Flash Replacement: paso 13, imagen 1 de 2 Canon PowerShot G7X Flash Replacement: paso 13, imagen 2 de 2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Flash Replacement: paso 14, imagen 1 de 2 Canon PowerShot G7X Flash Replacement: paso 14, imagen 2 de 2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Flash Replacement: paso 15, imagen 1 de 2 Canon PowerShot G7X Flash Replacement: paso 15, imagen 2 de 2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
Conclusión
Un comentario
Hi,
great guide, thanks!. Where can I buy the flash?
Best
david olivelli - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 118
Todo El Tiempo: 2,187
