Saltar al contenido principal
Canon PowerShot G12 Rear Function Setting Dial Replacement
Alexandra Millett
Alexandra Millett y 3 otros contribuidores
Última actualización: May 7, 2024
25 - 30 minutos
Difícil
Introducción
Ir al paso 1
Replacing the function dial is a highly-invasive, step-intensive process that becomes necessary if the function dial has sustained damage due to a crack or internal malfunction.
The function dial refers to the round mechanism on the lower back side of the camera identified by "Func. Set." In this guide, you will learn how to replace the function dial carefully without damaging any essential internal components.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Canon PowerShot G12 Rear Function Setting Dial Replacement, Rear Function Setting Dial: paso 1, imagen 1 de 1
    • Remove the three screws on the bottom of the camera using a Phillips-head 00 screwdriver.
  2. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 2, imagen 1 de 1
    • Remove all of the screws on both the left and right side of the camera.
  3. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 3, imagen 1 de 1
    • Looking at the front side of the camera, there is a port on left side of the camera labeled HDMI.
    • Remove the one screw on the side of the HDMI port.
  4. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 4, imagen 1 de 1
    • Remove the screw on the right side of the view finder on the back side of the camera.
  5. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 5, imagen 1 de 1
    • Using a spudger, carefully pry open the back side of the camera starting directly under the camera's serial label.
    • Make sure all sides of the back case are loose before trying to force it off of the camera. It should be removed with relatively little effort.
  6. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • The back case is still attached to the camera with a yellow ribbon cable. The socket has a black flip-up lid that must be flipped up before the cable can be removed. Use precision tweezers to remove the cable.
  7. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 7, imagen 1 de 1
    • Put the camera aside and look to the interior to the camera's back shell.
    • Peel off the thick, plastic seal over the metal plate near the yellow ribbon cable.
  8. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 8, imagen 1 de 1
    • Remove the four screws from the metal plate using a Phillips-head 00 screwdriver.
  9. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 9, imagen 1 de 1
    • Remove the spring from its socket using precision tweezers allowing the metal plate with the function dial to be removed.
  10. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 10, imagen 1 de 1
    • Using precision tweezers, pry the old function dial out of its socket leaving only a black, metal ring attached.
  11. Canon PowerShot G12 Rear Function Setting Dial Replacement: paso 11, imagen 1 de 1
    • Attach the new function dial simply by pressing it into the black, metal ring until you hear a click.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-5, Leahy Winter 2015 Miembro de USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 Miembros
6 Guías creadas
2 comentarios
Thank you so much!! I needed to replace the entire rear cover, because Canon doesn't sale just the wheel separately. your guide was the best one I found on the web. I think you ought to make a video of it, I admit I didn't see the "black flip-up" in part 6 so that part (putting the cable back in) was the most aggravating part for me.
But again thank you so much!
Maya Shemolewitz - Contestar
Very good guide, the only one I’ve seen so far. Thanks for that>
Philip Knowles
Philip Knowles - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 25
Todo El Tiempo: 3,404
