Saltar al contenido principal
Canon PowerShot G11 Rear Cover Replacement
Dustin Brinegar
Dustin Brinegar y 2 otros contribuidores
Última actualización: May 7, 2024
10 - 15 minutos
Fácil
Introducción
Ir al paso 1
Turning off the camera, removing the battery, and removing the memory card. Unplugging the camera from any device it is hooked up to.
Qué necesitas
Herramientas
Ver más…
  1. Canon PowerShot G11 Rear Cover Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Cover Replacement: paso 2, imagen 1 de 1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Cover Replacement: paso 3, imagen 1 de 1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Cover Replacement: paso 4, imagen 1 de 1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Cover Replacement: paso 5, imagen 1 de 1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Cover Replacement: paso 6, imagen 1 de 1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Cover Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Cover Replacement: paso 8, imagen 1 de 1
    • The rear cover is now unattached from the camera.
Conclusión
Una persona más ha completado esta guía.
Dustin Brinegar
Miembro Desde 01/21/15
688 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 5-6, Brown Winter 2015 Miembro de USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 1,130
