Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon PowerShot G11 Front Cover Replacement
Qué necesitas
  1. Canon PowerShot G11 Front Cover Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
    Pregunta a FixBot
    Agregar Comentario
  2. Canon PowerShot G11 Front Cover Replacement: paso 2, imagen 1 de 1
    • Remove the four screws on the left side of the camera.
    Pregunta a FixBot
    Agregar Comentario
  3. Canon PowerShot G11 Front Cover Replacement: paso 3, imagen 1 de 1
    • Remove the screw on the right side of the camera.
    Pregunta a FixBot
    Agregar Comentario
  4. Canon PowerShot G11 Front Cover Replacement: paso 4, imagen 1 de 1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
    Pregunta a FixBot
    Agregar Comentario
  5. Canon PowerShot G11 Front Cover Replacement: paso 5, imagen 1 de 1
    • Remove the screw to the right of the view finder on the rear of the camera.
    Pregunta a FixBot
    Agregar Comentario
  6. Canon PowerShot G11 Front Cover Replacement: paso 6, imagen 1 de 1
    • Use the spudger to crack open the case.
    Pregunta a FixBot
    Agregar Comentario
  7. Canon PowerShot G11 Front Cover Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
    Pregunta a FixBot
    Agregar Comentario
  8. Canon PowerShot G11 Front Cover Replacement: paso 8, imagen 1 de 1
    • The rear cover is now unattached from the camera.
    Pregunta a FixBot
    Agregar Comentario
  9. Canon PowerShot G11 Front Cover Replacement, Front Cover: paso 9, imagen 1 de 2 Canon PowerShot G11 Front Cover Replacement, Front Cover: paso 9, imagen 2 de 2
    • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
    Pregunta a FixBot
    Agregar Comentario
  10. Canon PowerShot G11 Front Cover Replacement: paso 10, imagen 1 de 1
    • Use the spudger to pop off front case.
    Pregunta a FixBot
    Agregar Comentario
  11. Canon PowerShot G11 Front Cover Replacement: paso 11, imagen 1 de 1
    • Pull the loosened cover off and you are finished.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 5-6, Brown Winter 2015 Miembro de USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 44
Todo El Tiempo: 2,862
