Saltar al contenido principal
Canon PowerShot G1 X Battery Replacement
Cleston Sanders
Cleston Sanders y 2 otros contribuidores
Última actualización: May 15, 2017
1 minuto
Fácil
Introducción
Ir al paso 1
Does your camera not power on or hold a charge? You may have a faulty battery that needs replacing.
  1. Canon PowerShot G1 X Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Pull the switch on the back of the battery case back towards the open arrow to release a latch.
    • The lid should pop open revealing the battery and a small red switch holding the battery in place.
  2. Canon PowerShot G1 X Battery Replacement: paso 2, imagen 1 de 2 Canon PowerShot G1 X Battery Replacement: paso 2, imagen 2 de 2
    • To release the battery, gently push the switch off the top of the battery and pull the battery out of the casing.
    • Place the new battery in the casing with the four metal connections (small squares on the bottom of the battery)in the bottom right hand corner of the bottom of the camera. If you look inside the casing you will see where the connections will meet. This will give you more of an idea on the orientation of the battery.
Conclusión
Equipo
USF Tampa, Team 20-1, Remmell Spring 2017 Miembro de USF Tampa, Team 20-1, Remmell Spring 2017
USFT-REMMELL-S17S20G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 467
