Canon PowerShot ELPH 310 HS Shutter Button Replacement
Introducción
Ir al paso 1The Canon PowerShot Elph 310 HS may have issues with the shutter button sticking. Replacing the button should only take a few minutes with these steps.
Qué necesitas
Herramientas
Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
Using your hands, remove the image stabilizer panel.
Using your hand, lift and remove the shutter button deck from the top of camera.
