Saltar al contenido principal
Canon PowerShot ELPH 310 HS External Panels Replacement
Kadie Aldridge
Kadie Aldridge y 2 otros contribuidores
Última actualización: December 24, 2015
15 minuto
Moderado
Fotos de acción
Necesita más imágenes
Introducción
Ir al paso 1
The Canon PowerShot ELPH 310 HS may experience some damage to the outer casings. If you need to remove the outer casings to replace another component, or need to replace the outer casing, follow this guide.
Qué necesitas
Herramientas
  1. Canon PowerShot ELPH 310 HS External Panels Replacement, External Panels: paso 1, imagen 1 de 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS External Panels Replacement: paso 2, imagen 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: paso 2, imagen 2 de 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS External Panels Replacement: paso 3, imagen 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: paso 3, imagen 2 de 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS External Panels Replacement: paso 4, imagen 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: paso 4, imagen 2 de 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS External Panels Replacement: paso 5, imagen 1 de 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS External Panels Replacement: paso 6, imagen 1 de 2 Canon PowerShot ELPH 310 HS External Panels Replacement: paso 6, imagen 2 de 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS External Panels Replacement: paso 7, imagen 1 de 1
    • Manually remove the front panel from the camera.
Conclusión
Un comentario
I have lost the two 4mm screws from the bottom of the camera and would like to buy replacements. Does anyone know the exact size of these screws?
Holland Van Ackeren - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 468
