Saltar al contenido principal
Canon PowerShot A630 Shooting Mode Dial Replacement
Alicia Burns
Alicia Burns y 5 otros contribuidores
Última actualización: March 22, 2020
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace the shooting mode dial on your Canon PowerShot A630 camera.
Qué necesitas
Herramientas
  1. Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: paso 1, imagen 1 de 2 Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: paso 1, imagen 2 de 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 2, imagen 1 de 2 Canon PowerShot A630 Shooting Mode Dial Replacement: paso 2, imagen 2 de 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 3, imagen 1 de 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 4, imagen 1 de 2 Canon PowerShot A630 Shooting Mode Dial Replacement: paso 4, imagen 2 de 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 5, imagen 1 de 2 Canon PowerShot A630 Shooting Mode Dial Replacement: paso 5, imagen 2 de 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 6, imagen 1 de 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 7, imagen 1 de 2 Canon PowerShot A630 Shooting Mode Dial Replacement: paso 7, imagen 2 de 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: paso 8, imagen 1 de 2 Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: paso 8, imagen 2 de 2
    • Pry open the connector on the yellow ribbon cable using a plastic opening tool.
  9. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 9, imagen 1 de 1
    • Remove the 2 mm screws from the metal plate.
  10. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 10, imagen 1 de 1
    • Pull away the metal plate, exposing the underbelly of the mode dial.
    • Be careful not to pull too hard. Metal plate should remain attached.
  11. Canon PowerShot A630 Shooting Mode Dial Replacement: paso 11, imagen 1 de 2 Canon PowerShot A630 Shooting Mode Dial Replacement: paso 11, imagen 2 de 2
    • Remove the 2mm screw using the #00 Phillips screwdriver.
    • The mode dial should fall out.
Conclusión
Una persona más ha completado esta guía.
Alicia Burns
Miembro Desde 10/13/14
645 Reputación
5 Guías creadas
Equipo
Clemson, Team 2-5, Benson Fall 2014 Miembro de Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 606
