Saltar al contenido principal
Canon EOS 30 LCD Screen Replacement
Sterling Vinson
Sterling Vinson y 4 otros contribuidores
Última actualización: February 21, 2020
15 minuto
Moderado
Imágenes Inconsistentes
Introducción
Ir al paso 1
This guide will show you how to access, remove, and replace the LCD screen. The process is safe and uncomplicated.
Qué necesitas
Herramientas
  1. Canon EOS 30 LCD Screen Replacement, Front Panel: paso 1, imagen 1 de 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 LCD Screen Replacement, Top Panel: paso 5, imagen 1 de 1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 LCD Screen Replacement: paso 8, imagen 1 de 2 Canon EOS 30 LCD Screen Replacement: paso 8, imagen 2 de 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 LCD Screen Replacement, LCD Screen: paso 9, imagen 1 de 1
    • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
    • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
  10. Canon EOS 30 LCD Screen Replacement: paso 10, imagen 1 de 1
    • Lift LCD screen out of mount.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 8-8, Regan Spring 2011 Miembro de Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Miembros
22 Guías creadas
2 comentarios
Thank's , your tutorial nice ... gracias
fajar - Contestar
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 5,430
