Saltar al contenido principal
Brother CS6000i Needle Plate Replacement
Ava Martinez
Ava Martinez y 2 otros contribuidores
Última actualización: December 31, 2024
15 - 20 minutos
Moderado
Introducción
Ir al paso 1
This guide will teach you how to replace the metal needle plate on the Brother CS6000i. You will need a Phillips #2 screwdriver as well as a 4mm flathead screwdriver. It will take about 15-20 minutes.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Brother CS6000i Needle Plate Replacement, Body: paso 1, imagen 1 de 2 Brother CS6000i Needle Plate Replacement, Body: paso 1, imagen 2 de 2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Needle Plate Replacement: paso 2, imagen 1 de 2 Brother CS6000i Needle Plate Replacement: paso 2, imagen 2 de 2
    • Pull the white cover off.
  3. Brother CS6000i Needle Plate Replacement: paso 3, imagen 1 de 2 Brother CS6000i Needle Plate Replacement: paso 3, imagen 2 de 2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Needle Plate Replacement: paso 4, imagen 1 de 3 Brother CS6000i Needle Plate Replacement: paso 4, imagen 2 de 3 Brother CS6000i Needle Plate Replacement: paso 4, imagen 3 de 3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Needle Plate Replacement, Needle Plate: paso 5, imagen 1 de 2 Brother CS6000i Needle Plate Replacement, Needle Plate: paso 5, imagen 2 de 2
    • Remove the two screws securing the needle plate with a 4mm flathead screwdriver.
Conclusión
Ava Martinez
Miembro Desde 10/31/24
433 Reputación
4 Guías creadas
Equipo
Cuesta, Team 20-1, Krynen Fall 2024 Miembro de Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
Miembros de 5
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 25
Todo El Tiempo: 58
