Saltar al contenido principal
Bottom Plate Removal
Sam Gustafson
Sam Gustafson y otro contribuidor
Última actualización: February 18, 2025
20 minuto
Fácil
Guía aportada por comunidad
Qué necesitas
Herramientas
  1. Bottom Plate Removal, Remove back cover: paso 1, imagen 1 de 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Bottom Plate Removal, Remove bottom cover: paso 2, imagen 1 de 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Bottom Plate Removal, Remove left front cover: paso 3, imagen 1 de 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Bottom Plate Removal, Remove front cover: paso 4, imagen 1 de 2 Bottom Plate Removal, Remove front cover: paso 4, imagen 2 de 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Bottom Plate Removal, Remove right front cover: paso 5, imagen 1 de 1
    • Remove two 3.9 mm #00 screws.
  6. Bottom Plate Removal, Prepare bottom plate: paso 6, imagen 1 de 2 Bottom Plate Removal, Prepare bottom plate: paso 6, imagen 2 de 2
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
  7. Bottom Plate Removal, Remove bottom plate: paso 7, imagen 1 de 2 Bottom Plate Removal, Remove bottom plate: paso 7, imagen 2 de 2
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
  8. Bottom Plate Removal, Remove transport gears: paso 8, imagen 1 de 2 Bottom Plate Removal, Remove transport gears: paso 8, imagen 2 de 2
    • It's best to remove these parts now so they don't fall out later on in the repair.
Conclusión
Sam Gustafson
Miembro Desde 09/01/22
7,682 Reputación
42 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 24
Todo El Tiempo: 327
