Saltar al contenido principal
Bosch 3727DEVS Governor Replacement
Daniel Riddle
Daniel Riddle y 3 otros contribuidores
Última actualización: May 2, 2016
10 minuto
Moderado
Introducción
Ir al paso 1
Purchase a new Governor. The sander should be unplugged from any power sources. Make sure you organize the removed screws, so you can reinstall them in the correct location.
  1. Bosch 3727DEVS Governor Replacement, Governor: paso 1, imagen 1 de 3 Bosch 3727DEVS Governor Replacement, Governor: paso 1, imagen 2 de 3 Bosch 3727DEVS Governor Replacement, Governor: paso 1, imagen 3 de 3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: paso 2, imagen 1 de 3 Bosch 3727DEVS Governor Replacement: paso 2, imagen 2 de 3 Bosch 3727DEVS Governor Replacement: paso 2, imagen 3 de 3
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: paso 3, imagen 1 de 1
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: paso 4, imagen 1 de 2 Bosch 3727DEVS Governor Replacement: paso 4, imagen 2 de 2
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 635
