Saltar al contenido principal
Azpen A701 Speaker Replacement
Grant Harding
Grant Harding y 2 otros contribuidores
Última actualización: December 6, 2018
Sin estimación
Moderado
Faltan Detalles
Introducción
Ir al paso 1
Replacing the speaker requires the use of a soldering kit. A guide to soldering is available on iFixit's website here.
Qué necesitas
Herramientas
Ver más…
  1. Azpen A701 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Wedge plastic spudger in between the back panel and the speaker of the device.
  2. Azpen A701 Speaker Replacement: paso 2, imagen 1 de 2 Azpen A701 Speaker Replacement: paso 2, imagen 2 de 2
    • Gently pry out the speaker from the back panel using the plastic spudger.
  3. Azpen A701 Speaker Replacement: paso 3, imagen 1 de 1
    • Heat solder and apply to the wires where they attach to the motherboard. This will disconnect the wires from the motherboard.
    • The wires should still be attached to the speaker.
  4. Azpen A701 Speaker Replacement: paso 4, imagen 1 de 1
    • Take the speaker and wires that are attached out of the device and insert a new speaker by soldering the wires to the motherboard.
Conclusión
To reassemble your device, snap back piece back on to device and secure both 2cm screws at the bottom.
Grant Harding
Miembro Desde 03/11/15
249 Reputación
2 Guías creadas
Equipo
Colorado Springs, Team 2-1, Panko Spring 2015 Miembro de Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
Miembros de 3
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 151
