Azpen A701 Screen Replacement
Introducción
Ir al paso 1The screen assembly is located underneath all of the other parts of the device. To access it, you will have to remove these pieces first. Make sure to keep track of all five screws and any connected parts.
Qué necesitas
Herramientas
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Disconnect the two larger of the three ZIF cables by prying open the flap with a plastic spudger and gently removing the cable.
Una persona más ha completado esta guía.
