Saltar al contenido principal
Asus X555LA-SI305041 Keyboard Assembly Replacement
Qué necesitas
  1. Asus X555LA-SI305041  Keyboard Assembly Replacement, Keyboard Assembly: paso 1, imagen 1 de 1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041  Keyboard Assembly Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041  Keyboard Assembly Replacement: paso 3, imagen 1 de 1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041  Keyboard Assembly Replacement: paso 4, imagen 1 de 1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041  Keyboard Assembly Replacement: paso 5, imagen 1 de 1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
Conclusión
13 personas más completaron esta guía.
2 comentarios
Truly useless guide
vic_1199 - Contestar
Could use some more steps on how to removed completely, including the touch-pad.
Can this be revised soon with more steps and pics? Please.
I need to replaced this keyboard because I have some non-working keys.
Frank P. - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 62
Todo El Tiempo: 8,336
