Asus X550ZA-SA100603E RAM Replacement
Introducción
Ir al paso 1This guide provides detailed step-by-step instructions to safely replace the RAM in the Asus Model X550ZA-SA100603E. If your laptop is lagging or running slowly, or if you wish to upgrade your RAM to boost performance, this guide may be helpful.
By following these steps, you can upgrade or replace the RAM and fix problems you may be experiencing with the memory.
Before you begin this repair, make sure to power off your laptop and unplug it from the charger. You should also backup your data before you start.
Qué necesitas
Herramientas
Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them.
Seven 14 mm screws
Three 4 mm screws
Una persona más ha completado esta guía.
