Saltar al contenido principal
Asus X502CA-BCL0901D Screen Frame Replacement
Gregory Browne
Gregory Browne y 3 otros contribuidores
Última actualización: May 7, 2024
1 - 5 minutos
Fácil
Introducción
Ir al paso 1
If you need to replace any portion of the upper part of your laptop: screen, webcam, etc. then you need to remove the screen frame first. This guide will show you how to do that.
Qué necesitas
Herramientas
Ver más…
  1. Asus X502CA-BCL0901D Screen Frame Replacement, Screen Frame: paso 1, imagen 1 de 2 Asus X502CA-BCL0901D Screen Frame Replacement, Screen Frame: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
  2. Asus X502CA-BCL0901D Screen Frame Replacement: paso 2, imagen 1 de 1
    • Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
    • The screws are 20 mm in diameter and 50 mm long.
  3. Asus X502CA-BCL0901D Screen Frame Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, pry the screen frame away from the screen.
  4. Asus X502CA-BCL0901D Screen Frame Replacement: paso 4, imagen 1 de 1
    • Using your hands, grasp the screen frame at it's base near the laptop hinge.
    • While pulling the base of the screen frame away from the hinge horizontally, also lift up on the screen frame to disconnect it from the laptop hinge.
    • The space between the screen frame and laptop hinge is very small and the plastic for both parts is weak. However, a fair amount of force is required to disconnect the screen frame from the laptop hinge. Be careful during this step, or either of these plastic pieces may break.
Conclusión
Gregory Browne
Miembro Desde 10/19/17
501 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G5, Bailey Fall 2017 Miembro de UMass Dartmouth, Team S3-G5, Bailey Fall 2017
UMASSD-BAILEY-F17S3G5
Miembros de 2
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 749
