Saltar al contenido principal
Asus X200MA Battery Replacement
Vanessa Garcia
Vanessa Garcia y 5 otros contribuidores
Última actualización: November 29, 2022
20 - 30 minutos
Moderado
Introducción
Ir al paso 1
If your battery is giving you a hard time on your laptop, follow this guide.
Qué necesitas
Herramientas
Ver más…
  1. Asus X200MA Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: paso 2, imagen 1 de 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: paso 3, imagen 1 de 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: paso 4, imagen 1 de 1
  5. Asus X200MA Battery Replacement: paso 5, imagen 1 de 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: paso 6, imagen 1 de 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: paso 7, imagen 1 de 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: paso 8, imagen 1 de 1
    • Slide the battery up and out.
Conclusión
30 personas más completaron esta guía.
Vanessa Garcia
Miembro Desde 01/22/15
1,796 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 21-24, Maness Winter 2015 Miembro de Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
Miembros de 4
8 Guías creadas
8 comentarios
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - Contestar
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - Contestar
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 59
Todo El Tiempo: 36,023
