Saltar al contenido principal
Asus VivoTab Note 8 Back Panel Replacement
Ryan Spencer
Ryan Spencer y 3 otros contribuidores
Última actualización: May 6, 2021
1 - 2 minutos
Fácil
Mejor introducción
Introducción
Ir al paso 1
Opening the back panel of the Asus VivoTab Note 8 is easy; however it is recommended to have a plastic opening tool to pry it off.
Qué necesitas
Herramientas
  1. Asus VivoTab Note 8 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. Asus VivoTab Note 8 Back Panel Replacement: paso 2, imagen 1 de 2 Asus VivoTab Note 8 Back Panel Replacement: paso 2, imagen 2 de 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. Asus VivoTab Note 8 Back Panel Replacement: paso 3, imagen 1 de 1
    • After pulling the panel off, put it to the side.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 15
Ultimos 30 días: 15
Todo El Tiempo: 561
