Saltar al contenido principal
Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement
Katie
Katie y 4 otros contribuidores
Última actualización: May 7, 2024
15 - 25 minutos
Moderado
Introducción
Ir al paso 1
This guide will walk you through the steps to replace a dead or non-working microphone in an Asus Tablet MeMo Pad 7 ME700C. Make sure you are using the proper tools and exercising caution while opening the back panel to avoid causing damage to the tablet.
Qué necesitas
Herramientas
Ver más…
  1. Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Back Panel: paso 1, imagen 1 de 2 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 2, imagen 1 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 2, imagen 2 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 2, imagen 3 de 3
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  3. Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 3, imagen 1 de 2 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 3, imagen 2 de 2
    • Pull the rear panel and the display screen away from each other.
  4. Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Battery: paso 4, imagen 1 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Battery: paso 4, imagen 2 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Battery: paso 4, imagen 3 de 3
    • Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
  5. Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 5, imagen 1 de 2 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 5, imagen 2 de 2
    • Remove the battery from the device.
  6. Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Microphone: paso 6, imagen 1 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Microphone: paso 6, imagen 2 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement, Microphone: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Disconnect the microphone plug from the motherboard.
    • Use the tweezers to gently pull the white plug from the motherboard.
  7. Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 7, imagen 1 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 7, imagen 2 de 3 Asus Tablet MeMo Pad 7 ME7000C Microphone Replacement: paso 7, imagen 3 de 3
    • Using the tweezers, peel back the silver adhesive, exposing the microphone.
    • Make sure you leave the tape adhered to the device for reassembly.
    • Gently remove the microphone with tweezers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 297
