Saltar al contenido principal
Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement
Serge Udovenko
Serge Udovenko y otro contribuidor
Última actualización: September 18, 2024
Sin estimación
Moderado
Guía aportada por comunidad
Introducción
Ir al paso 1
I haven't seen a guide on upgrading the m.2 SSD on the 2024 ASUS Rog G14 laptop. Here is a quick guide to whoever wants to attempt at upgrading their laptop.
I used the IFIXIT Essential Electronics Toolkit for this repair and a external M.2 drive enclosure to clone (copy) the C drive.
The 2024 ASUS ROG Zephyrus G14 GA403UV laptop came with a 1TB WD SSD drive and I wanted to upgrade the storage space. On this particular laptop the RAM is LPDDR5X and it is soldered on the motherboard, it has 16GB with no way of upgrading the RAM so the only upgrade I am able to do is to upgrade the storage space. The SSD upgrade I went with was the WD_Black SN850X NVMe Gen 4 2TB 2280 M.2 drive.
I installed the new drive into an external enclosure and cloned the drive using Acronis True Image for Western Digital to copy the existing drive to the new drive. The software was a free download from the Western Digital website and I was able to make an exact copy (clone) of the boot drive C.
After the clone process was complete all that was left was to remove the 1TB drive and to install the new 2TB drive, button up the laptop and boot it up. The laptop booted up without any issues, the only thing left to do was to install the drivers for the new drive to get the max speed of the new drive.
  1. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Tools and Parts Used: paso 1, imagen 1 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Tools and Parts Used: paso 1, imagen 2 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Tools and Parts Used: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    $29.95
  2. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Remove the Bottom Cover Screws: paso 2, imagen 1 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Remove the Bottom Cover Screws: paso 2, imagen 2 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Remove the Bottom Cover Screws: paso 2, imagen 3 de 3
    • After the clone process is complete go ahead and shut down the laptop and remove any usb drives, dongles, and power cord from the laptop.
    • Flip the laptop over and put it on a soft work pad, I used the laptop sleeve to protect the lid from getting scratches on it.
    • Remove the 11 screws that fasten the bottom cover with the Torx 6 bit. There are 2 rubber stoppers that need to be removed to get access to 2 of the screws. I used the toolkit lid to keep the screws organized since there are a few different screw sizes.
  3. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Pry Open the Bottom Cover: paso 3, imagen 1 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Pry Open the Bottom Cover: paso 3, imagen 2 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Pry Open the Bottom Cover: paso 3, imagen 3 de 3
    iFixit Opening Tool
    $1.99
    • After removing all 11 screws use the plastic Opening Tool to unclip the bottom cover
    • I started from the top right corner and worked all the way around the cover to unclip it
  4. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Take Time to Admire the Hidden Beauty: paso 4, imagen 1 de 2 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Take Time to Admire the Hidden Beauty: paso 4, imagen 2 de 2
    • After the bottom cover is removed inspect the laptop internals, now is a good time to remove any dust that might have accumulated.
    • If you are using compressed air be careful not to overspeed the fans, I usually keep a finger on the fan to keep it from spinning while air blasting it.
    • Take a moment to admire/inspect the laptop for any lose wires or screws.
  5. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Unhook the Battery Wire: paso 5, imagen 1 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Unhook the Battery Wire: paso 5, imagen 2 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Unhook the Battery Wire: paso 5, imagen 3 de 3
    Spudger
    $3.99
    • Before removing the SSD unhook the battery from the main board
    • Use the plastic Spudger Tool to remove the tape covering the battery connector
    • The metal cover the holds down the battery connector will need to be moved up out of the way. Once that is done you can use that Spudger Tool to pop up the battery connector.
    • I slid the metal cover back into position to keep the battery connector from coming in contact with the main board connection
  6. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Remove the Old SSD: paso 6, imagen 1 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Remove the Old SSD: paso 6, imagen 2 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Remove the Old SSD: paso 6, imagen 3 de 3
    • Once the power is removed from the main board you can start working on removing the existing SSD.
    • Use the Phillips 1 bit to remove the single screw holding the SSD in place.
    • Once the screw is removed lift up the end of the SSD and pull the drive out from the PCIe slot
  7. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Install the New SSD: paso 7, imagen 1 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Install the New SSD: paso 7, imagen 2 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Install the New SSD: paso 7, imagen 3 de 3
    • Once the existing drive is out simply slide the SSD out of the protective cover and slide it over the new drive
    • Install the new drive into the PCIe slot and reinstall the single Phillips 1 screw to hold the SSD in place.
  8. Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Connect the Battery and Reinstall the cover: paso 8, imagen 1 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Connect the Battery and Reinstall the cover: paso 8, imagen 2 de 3 Asus ROG Zephyrus G14 (2024) m.2 SSD Drive Replacement, Connect the Battery and Reinstall the cover: paso 8, imagen 3 de 3
    • Connect the battery back to the main board
    • Reinstall the cover and make sure you reseat all the clips around the edge of the cover before reinstalling the 11 screws
    • Finally reinstall the rubber bumpers on the bottom cover
    • I hooked up the power cord to make sure the charge light came on before powering the laptop back on
    • The laptop should boot up just fine if the clone process was successful, the only difference you should notice is a nice increase of storage space!
    • Congratulations you just upgraded you ASUS ROG Zephyrus G14 laptop!
Conclusión
Serge Udovenko
Miembro Desde 02/05/21
157 Reputación
1 Guía escrita
Un comentario
include a picture of the back of the top of the laptop to make model # easier to ID?
tonybilo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 32
Ultimos 30 días: 148
Todo El Tiempo: 973
