Asus ROG Strix GL702VS Webcam Replacement
Introducción
Ir al paso 1This is a step by step process for the replacement or repair of the webcam on your Asus ROG Strix GL702VS laptop. If you are experiencing bad quality or a black screen while using the webcam, follow these steps to remove the webcam and replace it.
Qué necesitas
Remove the two screw stickers at the bottom corners of the screen.
Remove the two 4mm JIS #0 screws beneath the stickers.
Gently lift the webcam out of its resting position at the top of the LCD assembly.
Una persona más ha completado esta guía.
