Saltar al contenido principal
Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement
Jackson Reynolds
Jackson Reynolds y otro contribuidor
Última actualización: December 27, 2018
2 - 3 minutos
Fácil
Mejor introducción
Qué necesitas
Herramientas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  1. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: paso 1, imagen 1 de 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: paso 1, imagen 2 de 2
    • Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
  2. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: paso 2, imagen 1 de 1
    • Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
  3. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: paso 3, imagen 1 de 2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: paso 3, imagen 2 de 2
    • Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
    • With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 11
Ultimos 30 días: 32
Todo El Tiempo: 313
