Asus MeMO Pad HD 8 ME180A Camera Replacement
Introducción
Ir al paso 1You will learn how to replace the camera. Review this guide if you are having difficulties with the camera. In order to replace the camera, you have to remove the battery and motherboard. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide and Asus MeMO Pad HD 8 ME180A Motherboard Replacement Guide to do so prior to starting.
Qué necesitas
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Herramienta utilizada en este paso:Anti-Static Wrist Strap$7.95
Ensure that you are wearing your Anti-Static Wrist Strap.
Upon removal of the motherboard, flip the motherboard to the side so the front-face camera faces you.
Remove the front facing camera.
