Saltar al contenido principal
Asus MeMO Pad HD 7 Front Facing Camera Replacement
Julien Daigle
Julien Daigle y 6 otros contribuidores
Última actualización: May 7, 2024
30 minuto
Moderado
En Progreso
Introducción
Ir al paso 1
The replacement guide for the front facing camera is simple and straight forward. This requires a little more work than replacing simple items like the battery. Never the less, the replacement of the camera can be accomplished with a few simple steps.
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Asus MeMO Pad HD 7 Front Facing Camera Replacement, Remove Rear Panel: paso 1, imagen 1 de 3 Asus MeMO Pad HD 7 Front Facing Camera Replacement, Remove Rear Panel: paso 1, imagen 2 de 3 Asus MeMO Pad HD 7 Front Facing Camera Replacement, Remove Rear Panel: paso 1, imagen 3 de 3
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
  2. Asus MeMO Pad HD 7 Front Facing Camera Replacement: paso 2, imagen 1 de 1
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Front Facing Camera Replacement: paso 3, imagen 1 de 1
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Front Facing Camera Replacement, Remove Battery: paso 4, imagen 1 de 3 Asus MeMO Pad HD 7 Front Facing Camera Replacement, Remove Battery: paso 4, imagen 2 de 3 Asus MeMO Pad HD 7 Front Facing Camera Replacement, Remove Battery: paso 4, imagen 3 de 3
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
  5. Asus MeMO Pad HD 7 Front Facing Camera Replacement, Motherboard: paso 5, imagen 1 de 1
    • Locate the speaker wires to the left side of the battery. Remove the connector by pulling up gently or prying with a tool if you can not get a good grip.
  6. Asus MeMO Pad HD 7 Front Facing Camera Replacement: paso 6, imagen 1 de 1
    • Pry the GPS Antenna cable straight up using a spudger or similar prying tool. It will be the grey wire that runs up the right side of the device coming from the speaker housing up to the motherboard.
  7. Asus MeMO Pad HD 7 Front Facing Camera Replacement: paso 7, imagen 1 de 1
    • Remove the data ribbon for the motherboard which is located on the right side of the board. It has a flat top on the connector. Remove it by using a spudger to pry it straight up.
    • Locate the volume and power button connector on the left side of the mother board. Disconnect the ZIF connector by flipping the latch on the connector up and sliding the data cable directly out.
  8. Asus MeMO Pad HD 7 Front Facing Camera Replacement: paso 8, imagen 1 de 1
    • Unscrew two #000 Philips 1.5 mm screws on the right side of the motherboard.
    • Unscrew 3 #000 Philips 2 mm screws from the left and center of the board.
    • The board will now lift straight up.
  9. Asus MeMO Pad HD 7 Front Facing Camera Replacement, Front Facing Camera: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    • With the motherboard removed flip it to the side with the front facing camera.
    • Using a pair of tweezers grab the camera and pull straight up to remove it.
Conclusión
Una persona más ha completado esta guía.
Julien Daigle
Miembro Desde 01/20/15
1,235 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 11-3, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G3
4 Miembros
5 Guías creadas
Un comentario
You forgot a couple very important steps. Before removing the motherboard, undo the clip that releases the power and volume button board. Also, there is a connector underneath the motherboard for the rear facing camera. Be careful not to break the connector or the ribbon cable. I can tell it's going to be tricky to reconnect it on reassembly.
Teletwanger - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 1,601
