Saltar al contenido principal
Asus GL551JW-AH71 Wi-Fi Card Replacement
William Kelley
William Kelley y 3 otros contribuidores
Última actualización: August 19, 2019
2 minuto
Moderado
Introducción
Ir al paso 1
This guide will provide a quick and easy procedure for replacing your Wi-Fi card. This particular guide could also be referred as a prerequisite for other guides on RAM, motherboard and fan.
Qué necesitas
Herramientas
  1. Asus GL551JW-AH71 Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Wi-Fi Card Replacement: paso 3, imagen 1 de 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: paso 4, imagen 1 de 2 Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: paso 4, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the two 16mm screws securing the access panel to the laptop.
  5. Asus GL551JW-AH71 Wi-Fi Card Replacement: paso 5, imagen 1 de 1
    • Gently remove the cover once the screws are removed.
  6. Asus GL551JW-AH71 Wi-Fi Card Replacement: paso 6, imagen 1 de 1
    • Locate the Wi-Fi card and detach both coaxial cables that are connected to the card.
    • The pictures in this step do not show a Wi-Fi card. The location where the Wi-Fi card would be located is indicated by the red rectangle.
  7. Asus GL551JW-AH71 Wi-Fi Card Replacement: paso 7, imagen 1 de 1
    • Grasp the Wi-Fi card gently and remove it carefully.
    • The pictures in this step do not show a Wi-Fi card, since it is missing from this particular device.
Conclusión
2 personas más completaron esta guía.
William Kelley
Miembro Desde 03/20/19
1,035 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 1,107
