Saltar al contenido principal
Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement
Stephanie Asling
Stephanie Asling y 2 otros contribuidores
Última actualización: January 4, 2018
10 minuto
Moderado
Introducción
Ir al paso 1
The left and right speaker bar is located underneath the hinge cover at the back of the laptop. Follow the steps in this guide to replace it.
Qué necesitas
Herramientas
  1. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Battery: paso 1, imagen 1 de 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 2, imagen 1 de 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 3, imagen 1 de 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: paso 4, imagen 1 de 2 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: paso 4, imagen 2 de 2
    • Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
    • Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
  5. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 5, imagen 1 de 1
    • Carefully turn the laptop right-side up.
    • Using an opening tool, pry the outer edges of the hinge cover up and away from the laptop.
    • The hinge cover, located at the back of the laptop, is the long plastic plate that covers the hinges and speakers.
  6. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 6, imagen 1 de 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 6, imagen 2 de 3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 6, imagen 3 de 3
    • Without disconnecting the speaker cable, set the hinge cover upside-down.
    • Hold the speaker cable by its white connector, then pull to unplug it from the motherboard.
    • You may need to apply some force, as these connectors can be difficult to unplug.
  7. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 7, imagen 1 de 1
    • The speaker is attached to the hinge cover by four 3.5mm Phillips #00 screws. Unscrew and remove them.
  8. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: paso 8, imagen 1 de 1
    • Lift the speaker to remove it.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 787
