Saltar al contenido principal
Asus G74SX-BBK7 Trackpad Button Replacement
Ryan Lawrence
Ryan Lawrence y 3 otros contribuidores
Última actualización: June 24, 2015
15 - 20 minutos
Moderado
Introducción
Ir al paso 1
The mouse button, located under the trackpad, includes a left and right side and is used for clicking on a computer. It can be extremely inconvenient to not have. This guide will teach you replace your mouse button.
Qué necesitas
Herramientas
Ver más…
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: paso 2, imagen 1 de 1
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: paso 3, imagen 1 de 2 Asus G74SX-BBK7 Trackpad Button Replacement: paso 3, imagen 2 de 2
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: paso 4, imagen 1 de 1
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: paso 5, imagen 1 de 1
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: paso 6, imagen 1 de 2 Asus G74SX-BBK7 Trackpad Button Replacement: paso 6, imagen 2 de 2
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: paso 7, imagen 1 de 3 Asus G74SX-BBK7 Trackpad Button Replacement: paso 7, imagen 2 de 3 Asus G74SX-BBK7 Trackpad Button Replacement: paso 7, imagen 3 de 3
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: paso 8, imagen 1 de 2 Asus G74SX-BBK7 Trackpad Button Replacement: paso 8, imagen 2 de 2
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: paso 9, imagen 1 de 3 Asus G74SX-BBK7 Trackpad Button Replacement: paso 9, imagen 2 de 3 Asus G74SX-BBK7 Trackpad Button Replacement: paso 9, imagen 3 de 3
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
Conclusión
2 personas más completaron esta guía.
Ryan Lawrence
Miembro Desde 04/14/15
611 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-10, Maness Spring 2015 Miembro de Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Miembros
6 Guías creadas
Un comentario
Where did you find the part?
websmiths - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 25
Todo El Tiempo: 4,887
