Saltar al contenido principal
Asus Chromebook C300SA-DS02 LED Screen Replacement
Celina Monteiro
Celina Monteiro y 5 otros contribuidores
Última actualización: December 10, 2019
15 minuto
Fácil
Introducción
Ir al paso 1
This guide will walk you through the step by step process of removing the LED screen from the laptop. Screen removal is a multistep process that will require you to keep track of the parts taken out of the laptop. Each screw is accounted for in the steps they are removed.
Qué necesitas
Herramientas
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: paso 1, imagen 2 de 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 2, imagen 1 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 2, imagen 2 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 2, imagen 3 de 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 3, imagen 3 de 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: paso 5, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 6, imagen 2 de 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 7, imagen 1 de 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: paso 8, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: paso 8, imagen 2 de 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 9, imagen 1 de 1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 10, imagen 1 de 1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 11, imagen 1 de 1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 12, imagen 1 de 1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 13, imagen 1 de 1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 14, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 14, imagen 2 de 2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Conclusión
2 personas más completaron esta guía.
Celina Monteiro
Miembro Desde 10/17/17
233 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Miembro de UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
Miembros de 3
9 Guías creadas
Un comentario
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 728
