Saltar al contenido principal
Asus Chromebook C300MA-DB01 Keyboard Replacement
Qué necesitas
  1. Asus Chromebook C300MA-DB01 Keyboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Keyboard Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Keyboard Replacement: paso 4, imagen 1 de 2 Asus Chromebook C300MA-DB01 Keyboard Replacement: paso 4, imagen 2 de 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 1
    • Use plastic opening tool to pry open clip holding keyboard wires to the circuitboard.
  6. Asus Chromebook C300MA-DB01 Keyboard Replacement: paso 6, imagen 1 de 1
    • Use plastic opening tool to pry open clip holding mouse pad wires to the circuit board.
    • Use plastic opening tool to pry open clip holding keyboard flat black wire
    • Use plastic opening tool to pry open clip holding keyboard thiner white wire
  7. Asus Chromebook C300MA-DB01 Keyboard Replacement: paso 7, imagen 1 de 1
    • Lift and remove keyboard from device.
Conclusión
wyatt boyatt
Miembro Desde 09/25/17
541 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S4-G3, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 281
