Saltar al contenido principal
Asus Chromebook C202SA-YS02 Screen Replacement
Qué necesitas
  1. Asus Chromebook C202SA-YS02 Screen Replacement, Bezel: paso 1, imagen 1 de 1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Screen Replacement: paso 2, imagen 1 de 1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Screen Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  4. Asus Chromebook C202SA-YS02 Screen Replacement, Screen: paso 4, imagen 1 de 3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: paso 4, imagen 2 de 3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: paso 4, imagen 3 de 3
    • Unscrew and remove the four screws holding the screen in place.
  5. Asus Chromebook C202SA-YS02 Screen Replacement: paso 5, imagen 1 de 1
    • Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 3,067
