Saltar al contenido principal
Anki Cozmo Speaker Replacement
Marisa Gay
Marisa Gay y 4 otros contribuidores
Última actualización: August 6, 2024
20 - 40 minutos
Moderado
Rebanar y Trocear
Introducción
Ir al paso 1
If your Anki Cozmo robot is emitting muffled or little to no sound, follow this guide. This guide is to assist users in replacing the speaker in an Anki Cozmo robot, so it can make noise again. The speaker, located in Cozmo’s head, allows it to make noise. Before beginning, make sure to power off your Anki Cozmo robot and disconnect it from the Anki Cozmo app.
WARNING: when using hands to remove any component, be careful not to cut yourself or rip your fingernail.
Qué necesitas
Herramientas
Ver más…
  1. Anki Cozmo Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Anki Cozmo Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Remove the two black rubber treads from the wheels using your hands to pull them off.
  2. Anki Cozmo Speaker Replacement: paso 2, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
    • There are four white hubcaps removed in this step. If your Cozmo is a different color, the hubcaps will also be the same color.
  3. Anki Cozmo Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
  4. Anki Cozmo Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
  5. Anki Cozmo Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
  6. Anki Cozmo Speaker Replacement: paso 6, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 6, imagen 2 de 2
    • Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
  7. Anki Cozmo Speaker Replacement: paso 7, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the front gold bumper using your hands and fingers to pull it off.
  8. Anki Cozmo Speaker Replacement: paso 8, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 8, imagen 2 de 2
    • Remove the two 5.5 mm screws that lay deep on the right side of the gold body using a JIS #0 screwdriver.
    • One screw is towards the front wheel and one screw is towards the back wheel.
  9. Anki Cozmo Speaker Replacement: paso 9, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 9, imagen 2 de 2
    • Pry off the two white arms from the right side of the body and the two white arms from the left side of the body using two metal spudgers.
    • Pry off the arms by digging the tips of each spudger in between the arm and the body and pushing up away from the body.
    • The short arm on the right side of the body has a long white spring attached to it that runs through the center of the body.
  10. Anki Cozmo Speaker Replacement: paso 10, imagen 1 de 3 Anki Cozmo Speaker Replacement: paso 10, imagen 2 de 3 Anki Cozmo Speaker Replacement: paso 10, imagen 3 de 3
    • Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
  11. Anki Cozmo Speaker Replacement: paso 11, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 11, imagen 2 de 2
    • Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
  12. Anki Cozmo Speaker Replacement: paso 12, imagen 1 de 1
    • Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
  13. Anki Cozmo Speaker Replacement: paso 13, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 13, imagen 2 de 2
    • Remove the right side of the white head using your hands and fingers to pull it off.
    • Do not unscrew or remove the two screws or the two white springs from the left side of the white head.
  14. Anki Cozmo Speaker Replacement: paso 14, imagen 1 de 1
    • Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
  15. Anki Cozmo Speaker Replacement: paso 15, imagen 1 de 1
    • Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
  16. Anki Cozmo Speaker Replacement: paso 16, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 16, imagen 2 de 2
    • Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
    • The camera and the speaker are attached to each other. They are removed in the same step.
Conclusión
3 personas más completaron esta guía.
Marisa Gay
Miembro Desde 10/28/21
702 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G8
3 Miembros
7 Guías creadas
2 comentarios
Great, do you know where to buy the speaker ?
Gilberto Torres - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 27
Ultimos 30 días: 82
Todo El Tiempo: 2,757
