Saltar al contenido principal
Amazon Kindle DX SIM Card Replacement
Hassan Haseeb
Hassan Haseeb y 7 otros contribuidores
Última actualización: August 25, 2024
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
The Kindle DX e-reader was introduced by Amazon in 2009.  It comes with a QWERTY keyboard and a d-pad.  The DX model comes with free worldwide 3G internet access that requires a SIM card within the device.
If the SIM card malfunctions in a Kindle DX, the user will not be able to download e-books via the 3G network.
This guide will provide step by step instructions to replace the SIM card.
 Warning: Turn off the Kindle DX e-reader before replacing the SIM card.
Qué necesitas
Herramientas
Ver más…
  1. Amazon Kindle DX SIM Card Replacement, Sim Card: paso 1, imagen 1 de 1
    • Use the plastic opening tool to push against the top part of the e-reader to open the device.
  2. Amazon Kindle DX SIM Card Replacement: paso 2, imagen 1 de 1
    • Remove the plastic top.
  3. Amazon Kindle DX SIM Card Replacement: paso 3, imagen 1 de 2 Amazon Kindle DX SIM Card Replacement: paso 3, imagen 2 de 2
    • Locate the two small screws on each corner.
    • Remove the two 40mm screws with a Phillips #0 screwdriver.
  4. Amazon Kindle DX SIM Card Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to take the off the metal plate.
  5. Amazon Kindle DX SIM Card Replacement: paso 5, imagen 1 de 1
    • Locate and remove the SIM card slot.
  6. Amazon Kindle DX SIM Card Replacement: paso 6, imagen 1 de 1
    • Use the spudger to push the metal lid backwards, as pictured.
  7. Amazon Kindle DX SIM Card Replacement: paso 7, imagen 1 de 1
    • Open the lid to replace the SIM card.
Conclusión
Una persona más ha completado esta guía.
Hassan Haseeb
Miembro Desde 09/28/16
189 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-5, Cagle Fall 2016 Miembro de USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
Miembros de 3
10 Guías creadas
3 comentarios
Need to do this with a kindle I have is does it need to be replaced with a 3G sim
Melanie Tague - Contestar
I have 10 kindle Docs, first or second generation. I am too old to use the new kindles, fire, paperwhites. Can I make my old kindles work? I have them for different genres, 3200 books total. Please before I’m too old to care. Thank you for your time. I’m desperate.
Lilli Bean
Lillibean - Contestar
DXs. Spellcheck messed up. Not me!
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 53
Todo El Tiempo: 3,606
