Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Amana Freestanding Electric Range Burners and Rims Replacement
Qué necesitas
    1. Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: paso 1, imagen 1 de 3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: paso 1, imagen 2 de 3 Amana Freestanding Electric Range Burners and Rims Replacement, Stove Burners and Rims: paso 1, imagen 3 de 3
      • Turn the knob for the desired burner to full heat.
      • If there is an unusual amount of heat or no heat, continue.
      Pregunta a FixBot
      Agregar Comentario
    2. Amana Freestanding Electric Range Burners and Rims Replacement: paso 2, imagen 1 de 3 Amana Freestanding Electric Range Burners and Rims Replacement: paso 2, imagen 2 de 3 Amana Freestanding Electric Range Burners and Rims Replacement: paso 2, imagen 3 de 3
      • Turn off the burner and let it cool.
      • Remove the burner after it has cooled by grabbing the edge and carefully pulling the element at a slight upward angle.
      Pregunta a FixBot
      Agregar Comentario
    3. Amana Freestanding Electric Range Burners and Rims Replacement: paso 3, imagen 1 de 1
      • Clean the burner element end with a wire brush or a metal sponge.
      Pregunta a FixBot
      Agregar Comentario
    4. Amana Freestanding Electric Range Burners and Rims Replacement: paso 4, imagen 1 de 2 Amana Freestanding Electric Range Burners and Rims Replacement: paso 4, imagen 2 de 2
      • Take one end of the element and bend it by 3.2 mm to make better contact with the socket inside.
      Pregunta a FixBot
      Agregar Comentario
    5. Amana Freestanding Electric Range Burners and Rims Replacement: paso 5, imagen 1 de 2 Amana Freestanding Electric Range Burners and Rims Replacement: paso 5, imagen 2 de 2
      • Place the new burner rim in the space with the hole for the element.
      • Make sure it is aligned with the socket.
      Pregunta a FixBot
      Agregar Comentario
    6. Amana Freestanding Electric Range Burners and Rims Replacement: paso 6, imagen 1 de 2 Amana Freestanding Electric Range Burners and Rims Replacement: paso 6, imagen 2 de 2
      • Gently push the restored element through the hole into the socket.
      Pregunta a FixBot
      Agregar Comentario
    7. Amana Freestanding Electric Range Burners and Rims Replacement: paso 7, imagen 1 de 1
      • Turn the knob to full heat after all steps are completed to test that it is working.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Refer to guides on repairing electrical components of electric stove burners or seek professional help if the guide does not help solve the problem.
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 20
Ultimos 30 días: 148
Todo El Tiempo: 2,157
