Saltar al contenido principal
Alcatel Jitterbug Smart Motherboard Replacement
Gavin Le
Gavin Le y 3 otros contribuidores
Última actualización: May 7, 2024
20 minuto
Difícil
Introducción
Ir al paso 1
Use this guide to replace the Motherboard in Alcatel Jitterbug Smart.
It's also an useful guide to help you to replace headphone Jack, camera and charging port.
Qué necesitas
Herramientas
Ver más…
  1. Alcatel Jitterbug Smart Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Alcatel Jitterbug Smart Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
  2. Alcatel Jitterbug Smart Motherboard Replacement: paso 2, imagen 1 de 3 Alcatel Jitterbug Smart Motherboard Replacement: paso 2, imagen 2 de 3 Alcatel Jitterbug Smart Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
  3. Alcatel Jitterbug Smart Motherboard Replacement: paso 3, imagen 1 de 2 Alcatel Jitterbug Smart Motherboard Replacement: paso 3, imagen 2 de 2
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
  4. Alcatel Jitterbug Smart Motherboard Replacement: paso 4, imagen 1 de 2 Alcatel Jitterbug Smart Motherboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Alcatel Jitterbug Smart Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Alcatel Jitterbug Smart Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Alcatel Jitterbug Smart Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
  6. Alcatel Jitterbug Smart Motherboard Replacement: paso 6, imagen 1 de 2 Alcatel Jitterbug Smart Motherboard Replacement: paso 6, imagen 2 de 2
    • Use a pair of tweezers to pull the black ribbon connector from its port.
    • Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Be careful to avoid damage the black connector or the wire connect the speaker to motherboard.
  7. Alcatel Jitterbug Smart Motherboard Replacement: paso 7, imagen 1 de 2 Alcatel Jitterbug Smart Motherboard Replacement: paso 7, imagen 2 de 2
    • Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
    • The motherboard will freely remove.
Conclusión
Gavin Le
Miembro Desde 02/13/18
523 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S11-G4, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G4, Cheng Spring 2018
USFT-CHENG-S18S11G4
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 358
