ASUS X533SA-BHCLN10 Battery Replacement
Introducción
Ir al paso 1In this guide we will be going through the process of replacing the battery. The process is not too hard and requires to first remove a number of screws. Follow the instructions carefully and diligently to be sure to not make any mistakes in the process. Changing the battery is a very simple task and with this guide you should easily replace it.
Qué necesitas
Partes
Herramientas
Ver más…
Turn over the laptop on the back panel.
Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
3 personas más completaron esta guía.
