Saltar al contenido principal
ASUS Padfone X mini Station Speaker Replacement
Alexzander Pastore
Alexzander Pastore y 3 otros contribuidores
Última actualización: May 7, 2024
20 minuto
Moderado
Introducción
Ir al paso 1
This guide will be helpful for repairing the speaker if the troubleshooting page recommends that you replace it. This is a necessary step when you have determined no other way to repair your current speaker.
Qué necesitas
Herramientas
Ver más…
  1. ASUS Padfone X mini Station Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Speaker Replacement: paso 2, imagen 1 de 2 ASUS Padfone X mini Station Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Speaker Replacement: paso 3, imagen 1 de 3 ASUS Padfone X mini Station Speaker Replacement: paso 3, imagen 2 de 3 ASUS Padfone X mini Station Speaker Replacement: paso 3, imagen 3 de 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  4. ASUS Padfone X mini Station Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  5. ASUS Padfone X mini Station Speaker Replacement: paso 5, imagen 1 de 3 ASUS Padfone X mini Station Speaker Replacement: paso 5, imagen 2 de 3 ASUS Padfone X mini Station Speaker Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  6. ASUS Padfone X mini Station Speaker Replacement: paso 6, imagen 1 de 2 ASUS Padfone X mini Station Speaker Replacement: paso 6, imagen 2 de 2
    • Use tweezers to detach the connecter from the motherboard.
Conclusión
Alexzander Pastore
Miembro Desde 10/26/18
389 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 191
