Saltar al contenido principal
ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement
Vinny Micale
Vinny Micale y 4 otros contribuidores
Última actualización: October 4, 2019
8 minuto
Moderado
Herramientas Incorrectas
Introducción
Ir al paso 1
Use this guide to replace the Touchpad and Mouse Buttons of your ASUS EEE PC701SD-WHI004X. Be sure to disconnect the laptop from all sources of power before beginning. This guide should be followed if the mouse does not respond to movement from the trackpad, or if the buttons will not click or are unresponsive.
Qué necesitas
Herramientas
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #1 Screwdriver
Ver más…
  1. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Battery: paso 1, imagen 1 de 2 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
  2. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 2, imagen 1 de 2 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 2, imagen 2 de 2
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
  3. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Keyboard: paso 3, imagen 1 de 3 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Keyboard: paso 3, imagen 2 de 3 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Keyboard: paso 3, imagen 3 de 3
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
  4. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 4, imagen 1 de 3 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 4, imagen 2 de 3 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 4, imagen 3 de 3
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
  5. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement, Touchpad and Mouse Buttons: paso 5, imagen 1 de 1
    • Remove all six 3.4mm Phillips #1 screws marked with red circles.
  6. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 6, imagen 1 de 2 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 6, imagen 2 de 2
    • On either end of the ribbon cable clamp, carefully push the tab towards the right, using a nylon spudger.
    • The ribbon cable can now be pulled out using the blue tab attached to the cable.
  7. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 7, imagen 1 de 2 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 7, imagen 2 de 2
    • Move the screen as far back as possible, and pry apart the plastic clips on the inside and outside of the hinges. They should be pushed upwards.
    • Use a spudger between the metal and white plastic, and carefully pry them apart to dislodge the clips.
  8. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 8, imagen 1 de 1
    • Pry the top cover off of the laptop. This should come off easily if you have removed all the tabs.
    • Be careful around the audio jack area. You may need to slide the cover towards the left and around the headphone and microphone jacks.
  9. ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 9, imagen 1 de 3 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 9, imagen 2 de 3 ASUS EEE PC701SD-WHI004X Touchpad and/or Mouse Button Replacement: paso 9, imagen 3 de 3
    • Flip over the top cover and unscrew the two 1.2mm Phillips #0 screws.
    • Remove the plate and the trackpad. They may come off separately.
Conclusión
Una persona más ha completado esta guía.
Vinny Micale
Miembro Desde 03/21/17
225 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,119
