Saltar al contenido principal
8BitDo Ultimate Wired Buttons Replacement
Tanvi Verma
Tanvi Verma y 3 otros contribuidores
Última actualización: May 31, 2024
25 - 55 minutos
Moderado
Introducción
Ir al paso 1
If you need to replace the buttons, you can access them with this guide. You may need to change the buttons if they are worn down, cracked, jammed, or missing. For this guide, you will need a plastic opening tool, Phillips #0 screwdriver, TR6 Torx Security screwdriver, and ESD-safe blunt nose tweezers (optional).
This repair process is not too difficult, but be careful to not damage anything when you take off the top panel. Make sure the controller is not plugged into a power source.
Qué necesitas
Herramientas
Ver más…
  1. 8BitDo Ultimate Wired Buttons Replacement, Buttons: paso 1, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement, Buttons: paso 1, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement, Buttons: paso 1, imagen 3 de 3
    • Orient the controller such that the back of the controller is facing you.
    • Insert an opening tool into the small opening on the back of the grip, and gently pry the grip cover away until it pops free.
  2. 8BitDo Ultimate Wired Buttons Replacement: paso 2, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 2, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 2, imagen 3 de 3
    • Pry the other grip panel off using the same method.
  3. 8BitDo Ultimate Wired Buttons Replacement: paso 3, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 3, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 3, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the top left 10.44 mm torx screw on the backside.
    • Use tweezers to help remove the screws (optional).
  4. 8BitDo Ultimate Wired Buttons Replacement: paso 4, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 4, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 4, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the middle left 10.44 mm Torx screw on the backside.
  5. 8BitDo Ultimate Wired Buttons Replacement: paso 5, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 5, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 5, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the bottom left 10.44 mm Torx screw on the backside.
  6. 8BitDo Ultimate Wired Buttons Replacement: paso 6, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 6, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 6, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the top right 10.44 mm Torx screw on the backside.
  7. 8BitDo Ultimate Wired Buttons Replacement: paso 7, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 7, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 7, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to remove the middle right 10.44 mm Torx screw on the backside.
  8. 8BitDo Ultimate Wired Buttons Replacement: paso 8, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 8, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 8, imagen 3 de 3
    • Use the TR6 Torx Security screwdriver to unscrew the bottom right 10.44 mm Torx screw on the backside.
  9. 8BitDo Ultimate Wired Buttons Replacement: paso 9, imagen 1 de 2 8BitDo Ultimate Wired Buttons Replacement: paso 9, imagen 2 de 2
    • Insert an opening tool into the small opening between the front and back panels, and gently pry the back panel away to open the bottom clamps of the top panel of the controller.
  10. 8BitDo Ultimate Wired Buttons Replacement: paso 10, imagen 1 de 2 8BitDo Ultimate Wired Buttons Replacement: paso 10, imagen 2 de 2
    • Insert an opening tool into the small opening between the front and back panel (top view) and pry away to remove the top half.
    • A ribbon cable connects the front and back portions of the controller.
  11. 8BitDo Ultimate Wired Buttons Replacement: paso 11, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 11, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 11, imagen 3 de 3
    • Use the Phillips #0 Screwdriver to remove all seven 6.14 mm Phillips screws from the button PCB.
  12. 8BitDo Ultimate Wired Buttons Replacement: paso 12, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 12, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 12, imagen 3 de 3
    • Remove the button PCB.
    • Pinch the silicone cover on the buttons to remove it, such that the buttons are exposed.
  13. 8BitDo Ultimate Wired Buttons Replacement: paso 13, imagen 1 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 13, imagen 2 de 3 8BitDo Ultimate Wired Buttons Replacement: paso 13, imagen 3 de 3
    • Simply using the force from your finger, push the button out of the housing.
    • Pull button out.
Conclusión
6 personas más completaron esta guía.
2 comentarios
From where to purchase spare parts, like buttons?
Mitko - Contestar
I purchased mine from the official store: https://shop.8bitdo.com/collections/repa...
Zarlin -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 44
Ultimos 30 días: 145
Todo El Tiempo: 1,572
