Saltar al contenido principal
2013-2015 Nissan Altima Low Beam Bulb Replacement
Rama Sura
Rama Sura y 2 otros contribuidores
Última actualización: May 11, 2023
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
In these steps, you will learn how to change a Nissan Altima light bulb the quick and easy way using household tools. Note: wear gloves if need. Fix can get very dirty.
Qué necesitas
Herramientas
  1. 2013-2015 Nissan Altima Low Beam Bulb Replacement, Low Beam Bulb: paso 1, imagen 1 de 2 2013-2015 Nissan Altima Low Beam Bulb Replacement, Low Beam Bulb: paso 1, imagen 2 de 2
    • Turn the steering wheel all the way to the left or right to grant access to the fender line. (Or in our case for better display, remove the wheel.)
  2. 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 2, imagen 1 de 2 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 2, imagen 2 de 2
    • Remove the fender liner using flathead screwdrivers by unscrewing all 3 locations holding fender liner to front bumper.
  3. 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 3, imagen 1 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 3, imagen 2 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 3, imagen 3 de 3
    • Now go to the underside of the fender liner and remove the three bolts using the Phillips screwdriver and flathead for the 1 clip.
    • Use same flathead screwdriver technique for the flathead highlighted in green.
  4. 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 4, imagen 1 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 4, imagen 2 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 4, imagen 3 de 3
    • Grab the small hole on the underside of the fender, and carefully pull the panel out.
    • This allows you to access the rear of the headlight housing.
  5. 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 5, imagen 1 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 5, imagen 2 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 5, imagen 3 de 3
    • Turn the lightbulb holder counter clockwise until it is released from the headlight
  6. 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 6, imagen 1 de 2 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 6, imagen 2 de 2
    • Pull up on the tab on the back of the bulb holder and simultaneously pull the light bulb out.
  7. 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 7, imagen 1 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 7, imagen 2 de 3 2013-2015 Nissan Altima Low Beam Bulb Replacement: paso 7, imagen 3 de 3
    • Replace the lightbulb by putting the new in place of the old one that was just removed.
    • Remember to insert the new light you must once again lift the tab while simultaneously inserting the new light bulb.
Conclusión
4 personas más completaron esta guía.
Rama Sura
Miembro Desde 02/13/23
433 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 72
Ultimos 30 días: 229
Todo El Tiempo: 6,020
