Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Esta unidad enfría o calienta el agua que circula a través del panel de refrigeración del ChiliPad. Modelo: CP-CUBE
NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @andrewlovell
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit Desmontaje del ChiliCube de ChiliTechnology guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
Imagen
(click on image)
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks for the info. I will let you know how i progress.
- de
Añadir tu respuesta
Andrew Lovell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 21
