Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una versión de la consola Nintendo Switch más asequible y exclusivamente portátil, con mandos Joy-Con integrados y una pantalla ligeramente más pequeña. Lanzada el 20 de septiembre de 2019.
Switch lite screen misaligned
Hi, my switch lite screen is misaligned and looks wonky. How would I go about fixing it? Is it possible to do without opening?
Imagen
Imagen
Imagen
Imagen
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hi!
Can you share some pictures with us, as how it looks like? This will help us to identify the issue.
Agregar imágenes a una pregunta existente
Most likely it's just the screen and yes you most likely do need to open it up.
But we cannot say anything for sure without the photos.
Thank you!
- de
Images added
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi!
Thank you for the pictures!
As in the last photo it's indeed slightly misaligned.
Since when did this happen?
Anyway, the only way to fix this, is to open it up and check how the screen is sitting in there. If possible, try to align it manually (carefully).
Those screens are incredible fragile, so be careful all the times.
In the worst case, a screen replacement is needed, but I don't think this will be the case.
Guide for how to get there: Reemplazo de LCD del Nintendo Switch Lite
Please let us know how it goes!
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
It is new, I noticed it after I set it up, problem is it's the japanese version so Nintendo won't accept the warranty in UK. I will try to get used to it for now as I know it isn't the worst but if not I will try the repair myself. Thanks for the responses.
- de
Ah, definitely a factory fault here. Whenever you go back to Japan, you can get it swapped for a new one. I agree, whenever it's completely new, I won't repair it as well. Have a great day!
- de
Añadir tu respuesta
Awais Ali estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 31
Todo El Tiempo: 194
