Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado originalmente en 2006, NeatDesk es un escáner de documentos de escritorio con ADF y funciones de dúplex completo. La revisión anterior tiene el número de modelo "ADF-070108" y la revisión más reciente es el modelo "ND-1000".
Why does it Scanning slow?
It was scanning at a fast pace and now it scans really slow.  Does anyone know how to fix this?  What should I be checking?   I have cleaned it thinking it might be dust but nothing.
Any suggestions are appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
Hi @nani11 ,
Does it do this when using the scanner's button controls, the Neat scanner software in a computer connected to the scanner or both?
- de
@jayeff
I press the PDF button to scan my documents or receipts and it scans really slow. I have a video but sure how upload it for you. Tk u for helping me.
- de
Agregar un comentario
1 Respuesta
Hi @nani11 ,
Is the scanner connected to a computer?
If so try re-calibrating the scanner and check if this resolves the problem.
Here’s a link to the section in the manual (is this your model?) that shows how to calibrate the scanner. Scroll down to “Calibrate your scanner” and then click on the Next page link to view the process.
Here’s a link that shows how to add media to your question on ifixit.
Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
@jayeff Still after the calibration
- de
Hi @nani11 ,
Can you try scanning from a computer to see if it is still slow or not?
Just wondering if you can maybe change the dpi settings for a scan using a computer which maybe you can't when using the scanner controls, to see if this makes a difference in scan speed or not.
Usually the higher the dpi the longer it takes to scan as it produces a more detailed scan.
If it makes no difference it could be a drive motor problem in the scanner
- de
Añadir tu respuesta
Jan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 650
