Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El smartphone insignia de Huawei del 2016. Presenta un cuerpo Unibody y una configuración de doble cámara trasera desarrollada en asociación con Leica. Viene en opciones de almacenamiento de 32/64 GB y seis acabados diferentes. Números de modelo EVA-L29, EVA-L19 y EVA-L09.
Camera App and Flashlight Not Working
I'd dropped my Huawei P9 a few months ago and the screen broke pretty badly. I finally ordered a LED+Digitizer from iFixit and got my screen replaced just last week. But now, when I try to open my camera app, the black rectangle animation of the app opening just barely reaches the edges of my screen before the app crashes/force closes. I've tried seeing if the camera will work on other apps, but it will force close Instagram and just gives me a black screen on Messenger.
I went back to the guy who helped me replace my screen. He opened my phone up again to check the camera pins and he said the camera pins were fine. He even connected my phone to the old screen again to see if there might've been an issue there(?) but the camera app and flashlight were still not working. He insists that it's a software issue and that I need to factory reset my phone, which I'm all but ready to do, but I wanted to reach out into the community and see if anybody had other ideas about what the issue might be.
It's a Huawei P9 EVA-L09. My camera and flashlight were working absolutely fine before the screen replacement. (Everything was still working smoothly except for the screen, really.)
Thanks in advance for any help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
12 comentarios
I have a P9 Plus and I have exactly the same problem. Even the trouble shooting part is exactly the same as my experience. Does any one know how to get t a diagnostic tool to test the hardware on Huawei Phones. Please help.
- de
I have the same problem on an P9 EVA-L09 with software version EVA-L09C432B398, The back camera works but as soon as you switch to the front camera, nothing works anymore and the app crashes. You have to force stop and reboot in order to get back camera functionality again, otherwise the app always crashes ?? This happened after a battery replacement (I have tested with a new front camera, it didn't help).
I'd be grateful for any sort of help!!
EDIT: Flash still works for me, but i first had to activate it from the lock screen. (it was blacked out in the quick toggles in the notification bar)
- de
I have the same issue. Camera app is showing a black screen for a second before fading away. I installed open camera, now selfie camera is not working. But I can use back camera. I factory reseted the phone, but still have the same issue!
- de
i also have similar problem recently. Is there anything can be done to solve this problem?
- de
I have same problems, when i try to open camera, snapchat, is screen black for one second and than throw me to backgound... this happens me after bettery change...
thanks for answers!
- de
Mostrar 7 comentarios más
Agregar un comentario
8 Respuestas
Respuesta Más Útil
Hey, you could indeed try to reset it. But I don't think that will help. While replacing the lcd did you disconnect the camera?
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I to have this issue i repaire phones as a living and automatically disconnect battery but customer came back saying camera not working could it be afault in the lcd ?
- de
I solved the problem of camera and flashlight missing on my Huwei P9. It was due to the loose connector that holds both devices pins inside the top part of the phone. It can happen after opening the phone to replace other parts, because you sometimes need to take away and put back this connection. It can also happen whent the phone falls, the connector gets loose. So you must ask for opening and attach again this connection. In my case we needed to do it several times before having it tight enough, otherwhy it would happen again after a few weeks. Luckily this part is easy to access.
Puntuación 1
1 comentario:
I have the same problem by the p30 pro. I have check the connectors of the camera's and reinsert these. Do you know a other solution?
Thanks in advance
- de
Let the battery discharge completely until the phone turns off. Charge the phone for five minutes. Then turn it on and test the camera. That worked for me. You do not need Hard reset or anything complicated
Puntuación 0
https://www.techjunkie.com/how-to-fix-ca...
“Restart the Huawei P9 (hold the “Power” button and the “Home” button at the same time for 7 seconds until the phone turns off and vibrates).
Go to Settings, open the Application manager and then go to the Camera app. Select on Force stop, clear data and clear cache. Restart your phone again”.
That worked for me. Good luck.
Puntuación 0
I just installed Open Camera and it is giving me the message that says “failed to open camera. Camera may be in use by another application? ID:0”
Puntuación 0
2 comentarios:
Just disconnected the main rear camera and the front facing camera is now working! I’ll see if I can source a rear camera.
- de
No open .come menu
- de
Nicou posted earlier that it might be an issue with the pins. That would make me think it’s a grounding issue where the pins contact the copper strips on the back side of the motherboard. I’ll try bending them out and cleaning the copper when I open it up again. I did find a rear camera on Amazon for the P20 and hopefully will have it by Friday.
Puntuación 0
It's because of electricity in the board.. try remove battery and after a minute connect it again. It will fix.. good luck.
Puntuación 0
Selfy camera no open...torch no open
Update (11/30/24)
Selfy camera ,torch no on
Puntuación 0
Añadir tu respuesta
Sally Zhang estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 35
Todo El Tiempo: 14,970
